    Default Dynasty 350 fingertip control
    Got a question concerning the Dynasty 350 and Miller fingertip controls. At work we have new Dynasty 350s with the Miller thumb-wheels controls. I haven't had and problems with them previously-but last night, I fired up and ran a bead. Everything was normal until I went to ramp down at the end of the bead.
    When I thumbed the control off, it didn't ramp the amps down as usual. Even when I had the control clicked all the way off-the torch continued to flame full blast! It took a full 2 seconds to finally ramp down. Seriously screwed up a nice bead!
    I know about the adjustments to set the time and amps to ramp up-ramps down your amps on the Dynasty using a button switch. But does this apply when you are using the thumb wheel control? I have never had this happen before. Any help will be greatly appreciated.
    Nov 2003
    3,512
    Smile
    My first guess is that it is not the finger control...
    but that somebody has "Doodled" with the sequencer control settings
    and possibly with the 2T, 3T, 4T settings
    goofed up your final slope time... on the machine itself
    FINAL SLOPE t
    (Final Slope Time)[FSLP] - Use control to set amountof time it takes to slope from weldamperage to final amperage. To
    disable, set to 0.
    take a look at section
    5-10. Sequencer Controls on page 45
    http://www.millerwelds.com/om/o216869af_mil.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    FINAL SLOPE t
    disable, set to 0.
    H80N,
    Thanks! I go back to work tonight. I'll grab some scrap and see if I can get it set back where it needs to be. I may just put it back into the factory defaults, and then go from there.
    Nov 2003
    3,512
    Quote Originally Posted by 'Stang View Post
    H80N,
    Also possible that it got set to another saved memory program..
    Check 5-13. Memory (Program Storage Locations 1-9) Page 48
    My Blue Stuff:
