Results 1 to 2 of 2
    Nov 2005
    117
    Default Trail Blazer 302
    Hello folks I need help I have a TB 302 runs on propane if it makes a difference, and I have and intermittent arc and 120 v problem anyone have experienced this? took it to L W S and worked on it but since is intermittent naturally " It was fixed" well back in shop again any help?
    8,351
    First off get a meter that reads frequency (HZ) shove the terminals in the 120 Vac receptacle. It must read 62.5 to 63 hz high idle no load adjusted at the engine. Don't know which engine you have...
