    Dec 2013
    Round Rock, Texas
    7
    Default straightening a trailer axle
    I am suspicious that the 3,500 pound rated axle may be high carbon steel and need to know if I should heat it or not. Someone has already reinforced it but the bend is always between the hub and the springs anyway. I want to strip the hub off, heat it and bend it straight. How do I put enough pressure on it without hammering the spindle and ruining it and any advice on aligning it without putting the hub and wheel back on. I was thinking about making a bar that would fit the backing flange and using that to bend the axle back. I would love a simpler way. Maybe a new axle?
    3,963
    Is the tube bent? or the spindle itself? I assume its a drop spindle. I have straightened them with a rosebud but making them perfect without putting the hub and tire back on is a pain. You can buy new spindles in all flavors and shapes. I just scrapped 40 or so when i emptied out my dads old trailer factory as i didn't have any room...Bob
    Lots of parts here http://www.rigidhitch.com/products/T...&CurrentPage=1
    Lodi, CA
    1,315
    3500# trailer axles are cheap enough it makes little or no sense to bother spending time, heat, money, or risk on them. Just go buy another one. Even better, spend a few more pennies and buy a 5200# axle.
    Dec 2013
    Round Rock, Texas
    7
    The is a low budget straight tube and the bend is usually at the area between the spring and the spindle. I would have to strip the bearings to heat it. I think to upgrade to a 5200 lb axle, it will require a 6 hole wheel. I need to get it off and check for cracks too. thank you.
    Dec 2013
    Round Rock, Texas
    7
    Default good advice
    I like your answer. But, I have 5 hole wheels now and I think to upgrade to a 5200 lb axle, it will require a 6 hole wheel. Is this correct?
    thank you.
    Nov 2012
    Northern Arizona
    566
    That is correct. But around where I am a trailer wheel is VERY cheap. And that is brand new. I bet selling that wheel and buying a 6-lug wheel would be a difference of only $20-30... Unless you get stuck moving to 16" wheels and have to get new tires. That could add a little but for the peace of mind of having heavier rated stuff I don't think you could go wrong. Plus you wouldn't have to screw around with axles in the future. Just some ramblings...
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
