Results 1 to 7 of 7
    Aug 2012
    Hermiston Oregon
    286
    Default spoolmate 100 cable length?
    I had an aluminum repair on a refer floor. And my spoolgun cable was to short. I belive its only 12' long does any one here know if they sale an extension. Id like to double the length.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    3,953
    You can't set your welder up there and use an extension cord on it? Might be cheaper. I have see some extensions but not for that gun...Bob
    Aug 2012
    Hermiston Oregon
    286
    Thats what I ended up doing . Anyway im going to take my spool gun apart and build my own 50'er . Any advise bob
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    3,953
    Quote Originally Posted by eecervantes83 View Post
    You may run short of weld power with that length. I know when i run .035 steel thru my spool gun i have to have my machine maxxed out and it doesn't weld well. Drop down a wire size and its fine...Bob
    Aug 2012
    Hermiston Oregon
    286
    I run .030 4043
    Ithink ill be ok
    I just took the spool gun apart
    Looks like the cable has a tube down the center and 4 cables
    2 for the switch
    2 for the motor
    Im thinking about leaving the spoolgun alone and building and extension with the 4 wires and tubing running on the outside.
    I think it will be better this way .
    And only hooking up the extension when needed.
    1. Ill need some brass machined to a female coupler.
    2. Brass hose fittings
    3. some 16g wire.
    4. A male end identical as the one found on the spoolgun.
    And I think that will get me going.
    Any advice guys
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    3,953
    Any advice guys
    As in the end of a normal Miller mig gun? I have at least 7 of them in my scrap pile...Bob
    Aug 2012
    Hermiston Oregon
    286
    Thanks bob
    I found part# 234236 @ miller4less @ $28.
    Its the same male plug found on the sm100.
    Any suggestions on how to run the gas hose out of the plug with out (interfering?) With the weld cable.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
