Results 1 to 2 of 2
    Apr 2012
    Oregon
    37
    Default syncrowave 250 has no remote amperage
    I recently purchased a Syncrowave 250 unit only, but I got a good deal on it. I tested it on scratch start and it worked fine. When I hook up the pedal, I have no remote amperage control. The machine runs at whatever amperage I have set on the dial. Local/ remote switch checks ok. What ohm readings should I get on the foot pedal? It's the RFCS-5 one. Machine serial is JJ385060. I have the owners manual and technical manual.
    Apr 2012
    Oregon
    37
    Never mind, found a bad wire on the pedal.
