Results 11 to 13 of 13
    Jul 2010
    Four Flags city
    304
    Eureka 5545 or Crown 55/45-10
    Jan 2014
    Washington, Mi
    Default I use certainum 89
    It's a awesome alloy. I use it for cast iron turbo exhaust housings to put a v-band flange on. I've never pre or post heated any cast iron using this filler. I've never had a v-band flange fall of or the weld crack. The stuff is not cheap per lb though.
    Feb 2013
    Canada
    107
    Default Tig welding cast iron?
    We have used nirods for few pieces of casting with tig, but we also done same pattern as usual
    Pre-heat /post heat+ wrapped it in a sandbox for the night!
    Worked well!!
