Results 1 to 3 of 3
    Dec 2013
    Default I can't get a Miller XMT304 to pulse mig
    At work I'm. Running a XMT304 with a series70 wire feed through a Northern Alabama pipe welder and when I switch the machine to pulse it shows ppp on the welder but the feeder doesn't switch over. When I try ro start to weld it just spits out wire without making an arc. I'm sure it's an easy fix but no one where I work is hip on pulse so they don't how to switch over.
    May 2013
    18
    You need a pulse controller.
    http://m.cyberweld.com/miopmigpuco.html
    Dec 2013
    Thanks I'll see if I can get work to buy it
