Results 1 to 10 of 19
Thread: Trailer repair
    1,897
    Default Trailer repair
    Had to go pick up an aluminum ramp to weld today. While I was there the driver/owner asked me about "putting a little weld on his trailer to make it stronger". "Maybe a brace too?" Holy crap! I told him no way am I going to just try to do a patch job. It needs to be fixed right as it is dangerous & will keep getting worse. I am supposed to come up with a price when I drop off the ramp. He was more worried about the deck being buckled & not flat then he was about the structure.
    Nov 2012
    Northern Arizona
    540
    Wow. Overloaded much? I'd like to know how that turns out. That is a lot of re-engineering to get that back up and rolling safely.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Aug 2012
    Hermiston Oregon
    278
    Looks like it will need new uprights.& a section of decking.
    Keep us updated. Looks like a good project.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Jul 2008
    Flin Flon & Creighton area
    233
    Default Thats a jackpot job!
    I agree with everyone here, this could be a very nice repair project to get the trailer back up to snuff. I guess it depends on if the owner will spend the money to do it properly. There are a lot of shady acres types that dont or are just too cheap to do it.
    As in another one of the replies , there is a certain amount of engineering , and liability. That unit would probly have to be inspected by the DOT? the sad thing is if they dont want to do it right you would be better to take out the torch and butcher it up for the good off everybody else on the road!
    I have a welding addiction
    Mpls, MN
    1,790
    Overloaded or was it in a collision?
    The bends look like the deck tried to keep going when the tongue didn't want to.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    1,897
    He told me that there was a car on the front deck & a large fork truck drove on the trailer to pick up the car. When the fork truck picked up the car that put all the weight about 18-24" behind the drop which just bent it. He did not have the landing gear down which if he did most likely would have been o/k.
    These trailers are built very lightweight. The upright tubes are 4x4x3/16" tube. My initial thoughts are cutting the lower deck loose from the uprights, with it disconnected & the landing gear down then carefully push down on the front of the top deck to get it straight. After it is straight then I will decide on the next move, either replace or repair. But at this point I'm just trying to come up with a number.
    Yes I know this is a big liability & needs to be done correctly.
    Dec 2010
    Andover, Ohio
    139
    Good luck with watever you decide to do.
    Oct 2009
    New Mexico
    43
    Good luck and make sure your insurance is up to date. I fight with my insurance all the time about jobs like this.
    Aug 2012
    Hermiston Oregon
    278
    Id recommend replacing the 4x4s they been compromise.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    3,948
    I would cut out all of the bad and start over. I also would make the gussets larger and run it down farther to the bottom channel like it isn't in pic 2. Also not to a point at the bottom leave some more meat...Bob
