Results 1 to 10 of 14
    Dec 2013
    25
    Default Miller Roughneck 1E diode help
    S/N: HE805340
    can anyone tell me which diode is missing from this pic? I have looked on diagrams and pics on the web but none show this diode on this board. Please help
    In case you are wondering, the underlying problem is only getting 40VAC to outlets and 1.5V on weld jackets.
    Dec 2013
    25
    Default more info
    I have replaced most of the diodes and I need to know the diode that is running vertically in between the two vertical columns of diodes, please.
    8,351
    Yep, looks like 11 diodes altogether, so yep that vert one is missing. Look like they are all the same so update it a little and stuff in all 2 amp 600 volt units
    Dec 2013
    25
    But what number diode is it so I can make sure it is oriented correctly
    8,351
    No one can tell you that unless they have one of those boards in front of them.
    Look at whats left of the one on the board. Can't help you aftr that. I suppose that if it blows, its the wrong way. Your installaton really needs refining.
    8,351
    The diagram ONLY shows the diodes in circuit. It does not show the diodes orientation on the board.
    Aug 2008
    Orange, TX
    1,223
    All 11 diodes are 3A, 600V and you can just barely make out the symbol on the board that the vertical one has the cathode (end with stripe) down.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Dec 2013
    25
    I see that now that you have pointed it out. Thank you duaneb55. Will update asap with results
    Mar 2011
    st-eustache qc.canada
    262
    Default pics that may help
    sorry i know nothing about boards but out of curiosity i found that, maybe you saw it...
    http://weldingweb.com/showthread.php...ghneck-1E-Help
    i think duane been there done that
    Dec 2013
    25
    Thanks snowbird. But that image doesent have the diode in question
