Results 1 to 2 of 2
    118
    Default Milwaukee 5196 heavy-duty die grinder - 14,500 rpm
    MILWAUKEE 5196 HEAVY-DUTY DIE GRINDER - 14,500 RPM
    Just purchased one of these. Finding grinding wheels that show the RPM required has become an issue. Does anybody know a site where I can purchase good stones and bit's for this tool, that operate within the tool's speed range.
    This is one **** of a good machine, heavy but very strong with it. I have been using steel brushes and they remove rust like a grinding stone. Have a few cheap stones that work well but wear quickly, so I know the quality or speed is an issue.
    Thank you for any help.
    Mar 2010
    488
    We used ours with flap discs so I'm not sure on rocks, but they are great tools even welding students had a hard time killing. If you do manage to wear out the end bearing near the collet etc, the parts are easy to replace.
    Sorry I can't be more help, but enjoy your tough new grinder!
