    Nov 2013
    12
    Default AR500 welding and bending
    For those who know more about this than me (pretty much everyone), I'm about to do some welding on a 3/8" AR500 plate. I'm not experienced welding hardened plate, would everyone recommend some preheat on this? I'll probably mig it up with my 252. I'm welding directly to about a 5/16" mild steel plate. The AR will serve as a wear plate and will drag the ground.
    Also, does anyone know if the AR500 can be bent if I can find someone with a large enough press break? It would help in this application if the front edge had a lip bent on it at about a 30 degree angle. Thanks,
    Justin
    Mar 2011
    st-eustache qc.canada
    259
    Smile
    it can be bent at longer radius than mild steel .
    you will find useful info there.
    http://www.ssab.com/Documents/North%...%2004%2001.pdf
    Jun 2009
    las vegas
    227
    500 is no prob to be bent. It will require a large press but the shop I used to be in did it all the time. As far as welding goes I don't think preheat would hurt but as previously posted check the charts
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    Nov 2013
    12
    Thanks for the info guys, those charts help. A local shop here has a huge press but they were concerned the steel might break instead of bend. I didn't think that was the case but knew you guys would know how it would react. Thanks again.
