Results 1 to 3 of 3
    Dec 2013
    1
    Default Dialarc HF problems
    Hey all,
    I have a Miller Dialarc HF Serial # - JG118889 that I am having some problems with.
    We switched the machine over to just a momentary switch for TIG welding. We have been using a switch from Weldcraft, however we keep burning them up and going through them about ever 2-3 months.
    I've gone through and replaced all the wiring from the receptacle to the switch itself and have installed a new switch....today while in the middle of welding it just cut out and the switch will not control anything.
    When the welder is in remote amperage setting and remote connector is off we can get an arc started...but with the remote connector switch on we don't get anything.
    Any suggestions on a momentary switch or options would be much appreciated.
    Jason
    Nov 2003
    3,566
    Quote Originally Posted by dieseljunky View Post
    Hey all,
    Jason
    On your Dialarc HF the remote switch carries the full load of controlling the 30 volts to the magnetic amplifier... and has no solid state control circuitry like more modern machines... they went brute force direct control.. that is all they had available at the time
    so I am surprised that your switches are lasting as long as they are...
    here is a link to your manual..
    http://www.millerwelds.com/om/o315m_mil.pdf
    for durability... I would guess a switch rated for at least 10 amps would live longer
    the factory pedal for that would be one of the RFC23 variants..
    here is a manual
    http://www.millerwelds.com/om/o826d_mil.pdf
    the "limit switches" specified are for 10 & 15 amps...
    hope this helps
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Nov 2003
    3,566
    Thumbs up
    Quote Originally Posted by H80N View Post
    here is a manual
    hope this helps
    That steam powered stuff like your Dialarc 250 HF welds beautifully…..
    is simple, rugged and heavily built…
    Nothing about them is delicate…or dainty....
    so expect repair parts to be heavy duty...
    My Blue Stuff:
    Millermatic 200
