Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
    Oct 2013
    8
    Default Welding black pipe (recently salvaged gas pipe)
    This is a request for information and safety concerns around welding salvaged black pipe from a residential renovation. It was being used to pipe natural gas from the city meter through a basement to various fixtures.
    I have an old but good AIRCO transformer welder with plenty of amps and was thinking 6010, 6011 rods.
    My idea is to cut the gas pipe into 15" lengths and weld them as rungs between 3"x2" angle to form a set of ramps that will get my car up a 16" incline needed to get it inside my shop.
    Any thoughts or suggestions would be most appreciated.
    Nov 2012
    Northern Arizona
    571
    How heavy of a car? Will you be tempted to drive heavier stuff up once the ramps are built? What schedule pipe? And last... what is the thickness if the angle?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Jun 2009
    las vegas
    227
    Wear a respirator if you decided to use it. I made that mistake a while back
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    1,928
    All the other questions plus how long will the ramps be? The longer they are the stronger they have to be.
    Oct 2013
    8
    Thanks for responding guys, here's the info.
    1. There's neither room inside, nor temptation to drive a deep ride or a backhoe up the ramps.
    2. Need to work on my 95 Toyota Corolla and 95 2-wheel drive tacoma: both light weight.
    3. Plan for ramps would be approx 7' in length running from ground level to 16" in height to get in the door - will add center support as well as support under the high end.
    4. Have looked at both 3/16 and 1/4" angle with rungs spaced 6" on center.
    5. At least 3/4" black pipe for the rungs.
    May be a dumb question, but asking anyway. Is there any risk of the metal having absorbed and retained any part of the explosive nature of the gas it held?
    Thanks again.
    1,928
    So basically you are building a set of trailer ramps but with a center support. If you already have the angle then use it with the 3" leg vertical. 3/4" pipe, probably sch 40, should work with the cars you mention but it really will not be that strong. If you have the pipe & it's free try it. The worst is it will bend slightly. I don't see it failing completely to cause damage. If I had to buy material I would not use pipe for this.
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by Bob61 View Post
    1. Need to work on my 95 Toyota Corolla and 95 2-wheel drive tacoma: both light weight.
    2. Plan for ramps would be approx 7' in length running from ground level to 16" in height to get in the door -
      Thanks again.
    1. If this is what I needed for these vehicles, I would build a ramp of compacted sand, and pour about a 3" thick slab of concrete over it to keep it there. No problems, no worries, and it's always there waiting for you when you need it. Save the black pipe for some other little project or maybe use some of it as rebar in the slab.
    Dec 2013
    476
    If this is what I needed for these vehicles, I would build a ramp of compacted sand, and pour about a 3" thick slab of concrete over it to keep it there. No problems, no worries, and it's always there waiting for you when you need it. Save the black pipe for some other little project or maybe use some of it as rebar in the slab.[/LIST]
    I wanted a thumb for my backhoe. I reworked a grapple from a log truck. Days later, I had a working thumb. Looks funny, works OK soon I will build one from scratch, and throw this mess away. When people try to make do with free material, the project never quite measures up. Grit your teeth, do it right. Years from now you will be proud, instead of making excuses why it doesn't quite work.
    1,928
    You can always get two 2x12x8' boards & block them underneath in two spots & you will be fine. Probably the cheapest & easiest.
    Oct 2013
    8
    Quote Originally Posted by Willie B View Post
    Thanks. When you say "do it right," if you have the time to tell, what would that actually look like?
Tags for this Thread
