Results 11 to 19 of 19
    Apr 2012
    Western Kentucky
    118
    Default Forgot to ask you
    Quote Originally Posted by gocirino View Post
    Made this for my AirPak... Top pops off so I can go in the truck while the dolly stays put.
    What kind of a bender did you use on that square tubing?
    if I can get half as good as some of you guys, I'd be happy.
    Syncrowave 200
    Millermatic 252
    Spoolmatic 30A aluminum gun
    Miller Spectrum 625 X-Treme
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Two big fire extinguishers
    "I'm a slow walker, but I never walk backwards" - Abraham Lincoln
    Apr 2012
    Western Kentucky
    118
    Default Wish I had known
    Yes, they are harbor freight SOLID RUBBER swivel ones. I used the air ones on my cart for the 180 SD. I like the solid ones for in the garage or on blacktop. The air jobs seem better on gravel or hard ground.
    gocirino, nice setup. I like that mag drill too.
    The inflatable tires I used from HF are a pain in the rear. Wish I had used the solid rubber ones for the shop instead. I have to get on my hands and knees to turn these tires by hand in order to get them to swivel properly. Each tire is rated for 300 pounds, however the Bobcat is heavy enough to prevent them from properly swiveling.
    Syncrowave 200
    Millermatic 252
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Nov 2012
    Northern Arizona
    547
    Quote Originally Posted by Gobysky:315343
    JD2 makes square dies. I'm sure others do too. J have been wanting to pickup a square die but u haven't come up with a use for it yet. This looks like a good use for one!
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    2,942
    I like it and wanted to do my 250 the same way. Still may. Are those Harbor freight casters?
    I made a cart for the 211, sort of done what MMW stated. It has been great for loading things up. Have the machine on it with plenty of room to carry about everything I need when moving from shop to trailer then back. Saves a lot of time when moving things.
    Attachment 33429
    This old shot is before I put expanded metal sides on it. Still have not painted it. Has a cradle under the bottom for a small gas bottle but found a long gas hose works great leaving the a big tank inside the trailer, nuther MMW suggestion.
    I used HF casters and they can be a pain to swivel in tight places. I'm still undecided if I want to move a 500lb machine in and out of a trailer, plus it would take a good hold down setup in a trailer while pulling it.
    Lets see the improvements when you make them.
    E-track on the floor or wall of your trailer if you don't have wood slats on the wall.- either one will work and then ratchet straps.
    All of our equipment carts are on wheels and our truck walls have wood slats- we just ratchet to the slats. Solid.
    2,942
    If you really need to turn tight over rough terrain you should redesign the cart with the wheels close together. Once you get heavy, the pneumatic casters just don't turn very good since they squish If yer in a shop with hard floors then a solid wheel caster is a better choice.
    Miller's design for off road.
    Same idea for us in this cable/sandbag cart- sees 500lb loads easy
    732
    Gobysky,
    Do you have difficulty loading the welder in and out of the cart?
    732
    Do you have any issues with protective cage rubbing on the sheet metal of your welder.
    22
    Quote Originally Posted by Gobysky View Post
    I used a 1-1/2" square die with my RDB-250 Baileigh Tubing bender.
    Dec 2013
    Round Rock, Texas
    7
    Default like
    That is a work of art. It is wonderful.
