Results 1 to 5 of 5
    Oct 2013
    1
    Default older bobcat models
    looking at used bobcats what is the difference between bobcat g and nt?
    May 2008
    Belle Plaine Iowa
    270
    Im bumping this up to the top because I want to know too.
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
    Feb 2009
    Lodi, CA
    1,313
    G is gasoline powered.
    I believe NT is New Technology.
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by blaze34 View Post
    The 225 G has 8000 watts of AC output from the generator end and the 225 NT is 10,000 watts. As far as any difference in weld output, I don't think there is really much difference. I have used both of these welders before. Mine is a 225 G, and we have a 225 NT here at work.
    The G & NT are both gasoline powered, with a Kohler engine. My G has a 18 HP where as the NT is 20 HP.
    May 2009
    Central North Carolina
    150
    We have a 224 NT and it only puts out 8,000 watts of 240 volt power, but that's enough to light every light both inside and outside of the house in a power failure - (a fun thing to do when the house is on the end of a peninsula in a lake and nobody has power anywhere around the shore of the lake). I'm not sure, but think the NT was added when they went to Silicon Diode Rectifiers and did away with the Selenium rectifiers. The rectifiers in our 225 NT are Silicon diodes.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
