Results 1 to 2 of 2
    Dec 2013
    Default REQ: Maxstar 152 - PC-300 info
    Hello,
    1. Has anyone connected the PC-300 directly to the Maxstar 152 for power? Since the Snap Start II can do this I think the PC-300 should be able to do this also.
    2. Has anyone found a good way to attach the PC-300 to the Maxstar 152 in a manner similar to the Snap Start II?
    8,230
    Probably work, though you have no HF, and thats used for the pulsing action. Not sure if the arc would stay alive , cause you'd likely have no background voltage either. Try it and see. Can't hurt anything...
Tags for this Thread
