Results 1 to 3 of 3
    Default needing a test schematic for xmt 304
    High all new to site looking for a test schematic for main board on a xmt 304 serial # Kj074271. Got a bad switch plus I think a diode burned on the board. As soon as i turn it on it blows main breaker its wired up single phase also any help would b great! Thanks in advance
    Oct 2004
    Edmonton, Alberta
    8,197
    Other than a occasional pulse transformer, the main board will not blow the breaker. More likely your input bridge (SR1) ,your output board and igbts are fizzled. Best look at them first.
    Ok thanks I'll do that first!
