Results 1 to 10 of 15
    Dec 2013
    10
    Default 1200# implement and 1/2"x3" flat bar
    I have an implement for a farm tractor that weighs 1200#s. I'm building a three point hitch mount out of A36 flat bar that is 1/2x3". The flat bar has 1-1/8" holes drilled in it 1-1/2" from the back and 1-1/2" from the top and bottom for an outside edge distance if 15/16" all the way around. The implement is 7' long overall with the 1/2" flat bar sticking 6" past unit. My question is: will the (4) pieces of 1/2" flat bar with the 1-1/8" holes be strong enough to pull and LIFT the implement?
    Apr 2013
    Southeast idaho
    30
    What kind of an implement? That will make a huge difference on weather or not it will be strong enough to pull it.
    Apr 2013
    Southeast idaho
    30
    Pictures would help
    Illinois
    632
    Picture would definitely help. Are you making the 3 point hitch like what's on a rear blade ? What type of implement ? Here's a search I did that may help.
    http://www.bing.com/images/search?q=...itch&FORM=IGRE
    http://www.bing.com/images/search?q=...ents&FORM=IGRE
    Dec 2013
    10
    Default Landplane grader
    The implement is a landplane grader. Ill attach some pics! The unit is 7'x7'. I plan on using (6)1/2x3"x12" pieces of bar across the front tube and attaching to the two center supports that are 32" apart.image.jpgimage.jpg
    Dec 2011
    425
    How big a tractor do you plan to use? I would keep the Cat II attachment as short as possible, not much more clearance than 1/2" behind the 3 pt. hitch arms in the pocket or if you need the extension for some reason maybe exterior gussets as far out as you can get without interfering with the pins. I don't know how heavy the tube is but the 1/2" x 12" reinforcement is a good idea I think. What are you using for the 3rd link?---Meltedmetal
    Dec 2013
    10
    Default Tubing size
    The center link will be mounted on the same 4"x4"x5/16" tubing 20" up in between the two lower links. I will be using the same flat bar. The flat bar is cut in 12" sticks but at least 6" will be welded to the cross tube and overlap the two supports in the middle. Tractor is a 58 horse ih784. Keep in mind this is where the hitch will attach to the impement: A36 flat bar that is 1/2x3". The flat bar has 1-1/8" holes drilled in it 1-1/2" from the back and 1-1/2" from the top and bottom for an outside edge distance if 15/16" all the way around. these (4) pieces are where the lower arms will slide into an attach. overall lenght may be 12 inches but only 4-6 sticking past the implement itself.
    Illinois
    632
    Dec 2013
    10
    You are correct BD1. I have the impelement built and it weighs a total of 1200#. I'm just not sure if what I have made, the (4) pieces of 1/2" flat bar with the 1-1/8" holes be strong enough to pull and LIFT the implement? The two grader blades I have will be cutting 1" below the skids at a width of 7'. I guess I'll put them on there and try it. If it doesnt work I'll cut them off and buy some 5/8"x4" flat and go again.
    Thanks guy for your time!
    John
    Dec 2011
    425
    I would expect that with 70 horsepower you will not have too much of a problem. The next question will be "Is your tractor big enough?" Looks good so far.---Meltedmetal
