Results 1 to 10 of 11
    Dec 2013
    Terrace
    7
    Default air arc settings
    I'm using a TB325efi to air arc with a 1/4 rod (air liquide) was wondering what the proper setting would be just doesn't seem to be working as well as it should Ive tryed a few settings and it works but just feel like it could be better any suggestions would be greatly appreciated
    Jul 2008
    Flin Flon & Creighton area
    233
    Default start with all the simple stuff first.
    Do you have the process selector set to SMAW or stick? Are your cables hooked up one to the ground(work) and the other to the Constant Current lead terminal? If you are you should be dc, now just the question of polarity, you want reverse or DCRP. Probably wouldn't hurt to set the ignition switch to full run , instead of run/idle. Other than having your air line hooked up and a good supply of air( 80 PSI minimum) you should be ready to rock and roll. Running full amperage at 325 burning 1/4 inch carbons is going to be hard on the machine in the long run, pay attention to your duty cycle. Having said that make sure you have cables to match the output and duty cycle if you are going hard at it. Minimum 2/0 cable and a good Copper Ground clamp. I like the Lenco 300 amp one. Might not hurt to turn the machine down and go with 3/16 carbons if your doing light duty or surgical finesse type gouging. I suppose it all depends on exactly what your doing. Hope this helps!
    I have a welding addiction
    Mar 2011
    103
    Carbon in the right posistion? Air stream has to follow the arc.
    Miller Trailblazer's ( 2 )...MillerBobcat 250...Millermatic 251's ( 2 )...Miller Syncrowave 200...Miller Syncrowave 180SD...Miller 12VS Suitcases ( 2 )... Hobart Hefty CC/CV Suitcases ( 2 )...Miller 30A Spool Guns ( 2 )...Miller WC 15A Control boxes ( 2 )...Thermo Dynamics Cutmaster 50 Plasma Cutters ( 2 )...Thermo Arc Hi Freq Units ( 2 )...Smith / Victor O/A Sets...DeWalt Power Tools...Craftsman / Snap On Hand Tools... Two Dodge Mobile Rigs
    Dec 2012
    Simcoe Ontario
    108
    First step rent a machine. Then hook up like normal stick welding crank it turn air on (90 psi+) and gouge away
    Mar 2010
    488
    My pipewelder bud wouldn't gouge with his machines. He use OA to gouge instead.
    Oswego IL
    797
    Default gouging
    I have a tb275, and prior 302. Hook leads to cc, turn selector to 6010 pipe. Turn amps to 250, gouge away, use 3/16, 1/4 to big for tb302. Also do not turn machine up to max, thats what will damage machine. Not sure why people are so worried about air arcing with machine, same to me as running big wire. Machine is designed for it. Probably gouged 500 hrs on machine, just so much faster and easier. Also be sure to have a good supply of air, 22cfm min, unless u have have the smaller air arc torch, (just bought one k2000, works very well with small compressors).
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
    1,919
    Your machine should gouge with 3/16 carbons & possibly 1/4". Some 302s can handle 1/4 & some can't, it's right at the limit. Set up dc+ & about 85-90% of power.
    What kind of compressor are you using?
    All good advice above except the rental part.
    Aug 2004
    Milan Michigan
    1,881
    I also think that you should be using a 3/16" carbon.
    I run 1/4" carbon at 350 amps.
    Yes you might be able to get a 1/4" to run but they recommend 3/16" for the 302 machine, I'm not sure about the 325.
    Have you ran a air carbon arc before to know what is good and what is not,
    A possible problem that no one mentioned is how much of the rod is sticking out of the torch, I grip a new rod at the 1/2 way point and pull it out as it gets used up, I never like to have more than about 4" sticking out.
    1,919
    As I was reading through Portable's latest post I realized the issue of electrode length. I had forgotten all about that. Many years ago we hired a "welder". He welded something wrong so I told him to just arc it out with the cac. After awhile he came over & told it was broke & not working right. He showed me with a new cac rod. He put it in the holder with the whole rod sticking out like a new stick rod. He never used one before & just assumed how it worked.
    Yes, make sure the stick out length is only about 4" or less. Also make sure the air holes are on the correct side of the rod & pointed the right way.
    Dec 2013
    Terrace
    7
    Thanks for all the suggestions I wasn't running the amps high enough ... Ya the 325 I'm using has a gouge setting. Also I was gouging through a toggle seat that was about 3-4 inches thick on a jaw crusher in a very awkward position so the deeper I got didn't seem to be blowing the slag away very well .. Also I'd get a few spots that had high carbon deposits from the rod so it would arc until I'd grind it down. Or that's what I figured not exactly sure y that happens
