Results 1 to 10 of 13
    Mar 2011
    st-eustache qc.canada
    259
    Default Is there a welding gas interchange chart between linde, praxair and airliquid ?
    Long story short, i switched from blueshield23 (ar-co2-oxygen) wich i liked (but not the suplyer) to linde argoshield 8c (92%ar-8%co2) wich i hate.
    Argoshield 8c runs colder, have to raise power on machine, spark is brighter may have to go one shade darker, does more spatters on the work and in nozzle... more spatter block, smoke etc...
    I know some welders dislike presence of oxygen in a shielding gas but for me and what i do it fits the bill perfectly.
    Any suggestions for an equivalent or a place to get an interchange of some kind?
    tahnk's
    Aug 2012
    Hermiston Oregon
    286
    Ive never heard of a welding gas with oxygen in the mix. U must be confused. The whole purpose of the inert gas is to keep oxygen away from the weld puttle. Oxygen = oxidation & porosity. Things you dont want .
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Aug 2012
    Hermiston Oregon
    286
    What you need is c-25. Minimal splattrr burns hotter because it contains more co2.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Nov 2003
    3,726
    Exclamation
    NOPE... You must be confused... gas selection depends on a number of factors
    and oxygen is often added to improve wetting... from what SNOWBIRD posted.. sounds like he is doing Spray Transfer...
    here is a link to the Praxair shielding gas manual... it will explain the physics of it... as well as the formulas and the reasoning behind them
    http://www.prest-o-sales.com/other_l...n%20Manual.pdf
    Quote Originally Posted by eecervantes83 View Post
    C25 is NO GOOD if you are going to spray transfer on ferrous metals.. most spray arc mixes have less than 10% CO2..
    BTW... while not commonly used in the US... the welding process that we refer to here as MIG (Metal Inert Gas)... is often referred to as MAG (Metal Active Gas) in other parts of the world... both O2 and CO2 would be considered "Active Gasses"
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Jun 2009
    las vegas
    227
    Your trying to keep nitrogen out of a weld and excess hydrogen. 2% or more oxygen is used for hotter welding or spray transfer. As previously posted.
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    Mar 2011
    259
    Default Thank-you HN80, you put me on track
    With your documented response and a little more time i found this link
    http://www.aoc.com.mx/biblioteca/tablas_conversion/COMPARATIVO_DE_GASES_DE_PROTECCION.pdf
    strictlycarved, i would not discard hydrogen too fast , a linde counter guy this morning, mentionned a gas containing some as an alternative for my regreted blueshield23...to be continued...
    thank's to all.
    Nov 2003
    3,726
    Thumbs up
    Thank You...
    that Gas cross reference is one that I did not have
    a valuable reference..
    we helped each other out...
    Quote Originally Posted by snowbird View Post
    strictlycarved, i would not discard nitrogen too fast , a linde counter guy this morning, mentionned a gas containing some as an alternative for my regreted blueshield23...to be continued...
    thank's to all.
    My Blue Stuff:
    Millermatic 200
    Dec 2013
    1
    Default gas
    Dear "Snowbird",
    Oxygen has a low ionization energy and impacts the surface tension of molten metal. As a component in the shielding gases it can therefore get you into spray mode at lower voltage settings and it supports finer droplets resulting in less spatter. On the flip side, out of position welding becomes difficult and you may loose (burn off) some critical alloying elements. Linde offers several three component shielding gases containing Argon, Carbon Dioxide and Oxygen.
    Please contact us to evaluate you specific needs at 1 888-256-7359 which will connect you with your local retail location.
    Mar 2011
    259
    Smile big brother is every where ;o)
    Thank-you jcaporali, i contacted my linde sales rep. and he had a few suggestions that will likely meet my expectations.
    I had no doubt about linde support, this posting was made to educate me from neutral point of view users here can provide.
    Very satisfied with linde response so far and wasn't expecting drawing your service/support's attention on this forum.
    Dec 2013
    Round Rock, Texas
    7
    Default correct information
    You are absolutely correct. I bet the poster meant CO2.
