Results 1 to 10 of 16
    Dec 2013
    25
    Default roughneck 1e help
    S/N: HE805340
    No power. Throttle switch not working properly. #1 wire not connected. Checked all other connection and seem good. Cleaned slip ringsMore info upon reqest. Thanks in advance for information.
    Nov 2003
    3,332
    Thumbs up
    Quote Originally Posted by amethyst161 View Post
    S/N: HE805340
    Here is a link to the manual..
    http://www.millerwelds.com/om/o419c_mil.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Dec 2013
    25
    Quote Originally Posted by H80N View Post
    Have manual but not keen on electrical schematics. Could not find #1 wire on schematics also
    Nov 2003
    3,332
    On the schematic..
    #1 lead is on the upper left on the "Engine Flywheel Alternator"
    marked right in the crook where the lead turns down... a little hard to see..
    My Blue Stuff:
    Millermatic 200
    Dec 2013
    25
    So two wires from engine alternator. One is by its self the other is connected to another wire and bolted to a small capacitor under carburetor. #1 should connect with the single wire?
    Dec 2013
    25
    I see that I had incorrect schematic. Thank you for posting correct one. Only 1 issue is the schematic shows a Tecumseh engine where mine has a Kohler.
    Aug 2008
    Orange, TX
    1,215
    The schematics in the correct manual link that H8N posted shows both the Tecumseh and Kohler engines.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Dec 2013
    25
    If I read it right then #1 goes only to the alternator? The wire coming from flywheel alternator must go to points I think?
    Dec 2013
    25
    Might have been a dumb idea but I jumped 12v + to the slip ring and was able to get power from 115v receptacle.
    Dec 2013
    25
    I was an idiot and soldered a diode in backwards. Replaced one more diode as well. Now have power to slip rings and receptacle. Only 45VAC at power throttle. I am getting power to my weld jacks as well. What else can be wrong to not get full 115VAC? I found bad diode by using multimeter and trace 12vdc power from alternator to PC board. Then found bad diode. Replaced diode and followed 12v + through capacitors and ended at slip rings.
