Thread: settings
    Default settings
    new welder fresh out of welding school... had trouble with my flux core and dual shield mig settings... would like some suggestions
    Need more info. Like what are you welding and what kind of welder.
    schedule 80 6in pipe mild steel, miller 350p
    1,794
    Did you look up the wire manufacturers specs & parameters for the wire you are using? That should be your starting point. Also check your machines feed for accuracy, ie physically measure the inches per minute to make sure it jives with the knob.
    Nov 2009
    11
    One thing you can do is download the welding calculator app from this website. Go to the resources tab and click on weld calculators and there will be an app that can be downloaded to your smartphone and always be available to you.
