Results 1 to 8 of 8
    Nov 2003
    3,584
    Unhappy Cruizer..Backfeeding line power to Bobcat 225G..
    Cruizer..
    here is a problem I saw posted on another site... think the guy did some major damage... what do you think..??
    ""Oops!!. Can Someone help me!!
    I have a Miller 225G welder/generator I have been using the generator lately to heat up a hot water tank which comes from the 220 on the generator to a 240v heating element just exactly like what is in your hot water heater! Being how I don't have a thermostat after about an hour when it is heated up plenty I shut the welder down unplug the cord and plug in another cord hooked to the same heating element into my 120v wall outlet to just maintain temperature!! So here is the oops!! The one time I forgot to unplug the 220v cord from the welder so it was charged from the 120v from the wall!! Now it barely turns over and builds what I would explain it as back pressure al
    almost like the Onan motor itself is turning backwards!!
    Please Help!!!! ""
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    8,231
    Well you stuck a neutral and ground into a live (hot) line. Think your power windings and half your rotor windings are cooked. Machine is cooked (unless its under warranty and don't tell anybody)...
    Nov 2003
    3,584
    Not me... but I figured he cooked it...
    My Blue Stuff:
    8,231
    Oh, well you can tell him from me that its cooked...
    Mar 2010
    488
    Classic thread.
    As the old saying goes,
    "A fool and his (welder repair money) are soon parted".
    226
    I don't understand how he did that. Did he make up a double male plug cord or dead mans cord.
    Aug 2008
    Orange, TX
    1,216
    "Now it barely turns over and builds what I would explain it as back pressure almost like the Onan motor itself is turning backwards!!
    Please Help!!!! ""
    I concur with cruiser that he fried the stator. Have seen the same symptoms described with generators that have fried and shorted stators. In fact have an exact example in the shop at the moment awaiting a replacement stator.
    I highly doubt the rotor is bad because it's inducing its magnetic field that is bucking the shorted stator windings hence the reason the engine "barely turns over". Again, seen the same exact symptoms with straight generators.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Nov 2003
    3,584
    Question
    It struck me as a strange but interesting problem...
    do not know if the poster will ever tell us the resolution...
    he seemed pretty embarassed at his lapse and the subsequent mayhem...
    My Blue Stuff:
