Results 11 to 11 of 11
    PA
    369
    migrapefarmer ,
    popspipes has good advice.
    Since you want to keep temperature low, I will offer this.
    At a job many years ago, we needed to make electrical
    connections to a 1/4" x .020 wall 316 stainless tube.
    Wire was 18 gauge stranded tin-plated copper with teflon TFE insulation.
    Used Blitz flux and plain 60/40 tin/lead solder with a 40 watt soldering iron.
    All joints needed to be cleaned very well after soldering as the flux is very corrosive.
    But we made all good joints using this flux.
    Today lead is a no-no so I tried a few tests using my 5% Ag - 95% Sn
    solder and the results were the same.
    440 stainless contains chromium which forms an oxide which makes soldering tough.
    The right flux makes all the difference.
    Plus - clean - clean - clean
    I have included info on the flux.
    Good luck
    http://www.force-industries.com/
    Force Industries Division
    American Solder and Flux Co., Inc.
    28 Industrial Boulevard
    Paoli, PA 19301-0947
    Phone 610-647-3575
    Fax 610-647-2375
    Email sales@force-industries.com
    Attached Files Attached Files
