Results 1 to 10 of 11
Hybrid View
    Default Silver Solder & Flux Question for 440C Stainless (AMS 5630) on Steel
    I have a difficult question. I am attempting to silver solder a 440C Stainless (AMS 5630) “doughnut” ring that is .5” long x .25” wall thickness onto a cast iron shaft. The .25” wall is not consistent and can grow to .45” on one side. The sstainless has been hardened to a Rc63-68 (knowing that I will lose some hardness out of the material). Both piece surfaces were sandblasted with a 1200 grit and have a .002” to .003” clearance fit. The shaft o.d. is .750"
    I went to the local welding shop and they recommended a 4% sliver solder and a flux (flux is at my shop). I practiced on test pieces that were both steel (not the stainless) and results were very good. When heating up the test pieces and disassembling, they both retained a silver coating. When I try the stainless onto the steel, the solder does not seem to want to “stick”. It will flow into the joint, but it does not provide any metal bonding. The internet provides a million options. It appears as if the solder and flux that I have are not appropriate for the application.
    I am getting the heat to it ~350 -375F. The solder appears to flow and go to the heat, but it just does not want to stick or make bond.
    Suggestions for both a Solder and a flux please, part numbers, pricing, where to get the supplies....
    Thank you and regards,
    Migrapefarmer
    Jun 2009
    las vegas
    227
    I would suggest getting it hotter. Not much more maybe to the. 400 but I hope some on here with more experience than I in that field
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    Dec 2011
    416
    Try here : http://www.lucasmilhaupt.com/en-US/products/ I've used their Handy flux for many years and been quite happy with it. It is not sticking to the steel or the stainless or both? As mentioned you may not be hot enough.---Meltedmetal
    Thank you for the input. Not sticking to both. I did try hotter with no luck. Because of the shape and physical confines, I am only able to heat the thinner side of the ring (about 130° radial). I will contact the supplier mentioned. If there is other input, I greatly appreciate the help.
    regards,
    MIgrapefarmer.
    Dec 2011
    416
    I'm guessing your using something like their "clean 'n bright" where I would try something more in the line of their "braze 505" or maybe "braze 450". But your looking at a lot more heat. Maybe sign in over there and peruse their product literature etc. Anyway I'm sure they can give you good advice.---Meltedmetal
    P.S. Some Handy and Harman or similar products may be available at your local welding supplier.
    Default You folks are good people....3 steps forward, 1 step back....it could have been 2
    I want to thank those here on this forum. I have been on other forums where it is hard to get input.
    I contacted lucasmilhaupt. Great company tech rep. I will recommend their products from this point out due to the help he gave me. Here is the answer. The cast is not good to solder due to the carbon content. He did indicate that I could get Nickle or Copper plating and then silver solder and it would work.
    In parallel to the above, I am also exploring MIG options. I have what I call "Farm Wire" and some Stainless that I have utilized before. I know the stainless that I have takes some amps (heat) to make it flow good (utilizing tri gas). I thought there was a wire out there that was utilized for body work that had a low melting point. I have welded stainless with both the wires and it appears to be ok (structurally ok for the application also).
    Thoughts of trying to MIG a stainless to a cast iron? I guess one test is worth it.
    I know I am being vague, apologies, but if you have a recommendation for a MIG wire type/diameter to weld a stainless to cast iron (see previous for the sizes/application), it again, is appreciated.
    regards,
    MIgrapefarmer
    Mar 2009
    Hazelwood Mo USA
    462
    Quote Originally Posted by migrapefarmer View Post
    Migrapefarmer
    I soft soldered (2% silver bearing) stainless cheese knives that were 304 stainless. The wires were stainless as well and I used Sta-Kleen flux, heating it is the trick, any over heat or direct flame heat to the joint is a no no. Once stainless tarnishes the solder wont stick and the flux wont clean it off. Stainless is a bear to solder anyway and any discoloration of the base metal will result in problems thats a fact.
    I would string the knives then flux the joints and solder with a large iron, making sure everything was clean and free of tarnish.
    The sta kleen flux was what we used, I never found anything better in the 35 plus years of doing them. We bought the flux from a welding supplier.
    Soft soldering cast iron I have no experience with.
    I also have silver brazed (high temp) 440 stainless with good luck if indirect heat is used.
    mike sr
    PA
    363
    migrapefarmer ,
    popspipes has good advice.
    Since you want to keep temperature low, I will offer this.
    At a job many years ago, we needed to make electrical
    connections to a 1/4" x .020 wall 316 stainless tube.
    Wire was 18 gauge stranded tin-plated copper with teflon TFE insulation.
    Used Blitz flux and plain 60/40 tin/lead solder with a 40 watt soldering iron.
    All joints needed to be cleaned very well after soldering as the flux is very corrosive.
    But we made all good joints using this flux.
    Today lead is a no-no so I tried a few tests using my 5% Ag - 95% Sn
    solder and the results were the same.
    440 stainless contains chromium which forms an oxide which makes soldering tough.
    The right flux makes all the difference.
    Plus - clean - clean - clean
    I have included info on the flux.
    Good luck
    http://www.force-industries.com/
    Force Industries Division
    American Solder and Flux Co., Inc.
    28 Industrial Boulevard
    Paoli, PA 19301-0947
    Phone 610-647-3575
    Fax 610-647-2375
    Email sales@force-industries.com
    Attached Files Attached Files
