    Aug 2013
    12
    Default welding ford e250 exhaust pipe.
    I need to cut out and replace a piece of exhaust pipe on a ford e250 van. Is the tubing galvanized or aluminized. What is the proper prep required. Also I will be tig welding it. What kind of filler rod should I use. Is there anything I should do after welding such as coating it with something to avoid corrosion.
    Oswego IL
    823
    Default if its after 1986....
    After 1986 it is a low grade stainless, thus the reason for rust. I normally use standard mig wire, just be sure in clean on the inside and outside.
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
    Jun 2009
    las vegas
    227
    Second that. Just mig it with the solid wire and make sure it's really clean. Did something similar to that about a year ago turned out great
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    4,513
    Mig is for 150 trucks.
