Results 1 to 10 of 20
Hybrid View
    Nov 2013
    7
    Default Aluminum Block Welding ?
    I need to build up an area on the rear bellhousing flange of an aluminum block (356 T6)
    I had a .875" thick piece of 6061 welded to the casting in order to machine a pad to accept a starter mount (the block originally had no provisions for an onboard starter) but the starter block ended up being 1" thick, so I need to build up this area (aprox. 6" long by 1" wide) in order to match the width of the starter block.
    I have limited experience welding aluminum, and that is on much thinner material than what I will be working with here. The machine that I have access to is a Miller Syncrowave 350, and I have just about any filler rod, tungsten grade and sizes available to me.
    I'm looking for any input as far as procedure, machine setting, filler rod, etc. to help me be successful completing the job.
    Thanks, Dave
    Nov 2003
    3,690
    Quote Originally Posted by hotrod1442 View Post
    Thanks, Dave
    Best filler these days for 356 is Hobart/Maxal 4943..
    Relatively new on the market... but neat stuff..
    http://www.maxal.com/Hobart_Maxal_4943.pdf
    here is a recent thread on 4943
    http://www.millerwelds.com/resources...highlight=4943
    and if you could get use of a Dynasty 350... it would be relatively simple..
    Chris Razor does some very nice work on cast..
    here are a few videos worth watching before you start..
    http://www.youtube.com/watch?v=OUr2hMIrDfo
    http://www.youtube.com/watch?v=ohuoWdZ7fW0
    http://www.youtube.com/watch?v=N9aqMknf_0g
    http://www.youtube.com/watch?v=Oh5n9fHdGjM
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Nov 2003
    3,690
    Question Aluminum DRCE Engine Block..???
    Is this the Block you are working on??
    Aluminum Olds Racing Block??
    http://www.gmpartsdirect.com/perform...ATID=1323.html
    My Blue Stuff:
    Millermatic 200
    Nov 2013
    7
    Quote Originally Posted by H80N View Post
    Yes, it is a KB Olds block
    Nov 2003
    3,690
    Smile
    Had a feeling that might have been the one...
    My Blue Stuff:
    Millermatic 200
    Nov 2003
    3,690
    Question
    Only 87 miles from Sarnia to Chris Razor's shop in Plymouth, MI...
    you might consider having him do the welding for you..
    it is a pretty expensive block.. and you may not want to practice on it..
    just a thought..
    My Blue Stuff:
    Millermatic 200
