Results 1 to 10 of 20
    Nov 2013
    7
    Default Aluminum Block Welding ?
    I need to build up an area on the rear bellhousing flange of an aluminum block (356 T6)
    I had a .875" thick piece of 6061 welded to the casting in order to machine a pad to accept a starter mount (the block originally had no provisions for an onboard starter) but the starter block ended up being 1" thick, so I need to build up this area (aprox. 6" long by 1" wide) in order to match the width of the starter block.
    I have limited experience welding aluminum, and that is on much thinner material than what I will be working with here. The machine that I have access to is a Miller Syncrowave 350, and I have just about any filler rod, tungsten grade and sizes available to me.
    I'm looking for any input as far as procedure, machine setting, filler rod, etc. to help me be successful completing the job.
    Thanks, Dave
    Nov 2003
    3,846
    Quote Originally Posted by hotrod1442 View Post
    Thanks, Dave
    Best filler these days for 356 is Hobart/Maxal 4943..
    Relatively new on the market... but neat stuff..
    http://www.maxal.com/Hobart_Maxal_4943.pdf
    here is a recent thread on 4943
    http://www.millerwelds.com/resources...highlight=4943
    and if you could get use of a Dynasty 350... it would be relatively simple..
    Chris Razor does some very nice work on cast..
    here are a few videos worth watching before you start..
    http://www.youtube.com/watch?v=OUr2hMIrDfo
    http://www.youtube.com/watch?v=ohuoWdZ7fW0
    http://www.youtube.com/watch?v=N9aqMknf_0g
    http://www.youtube.com/watch?v=Oh5n9fHdGjM
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Nov 2003
    3,846
    Question Aluminum DRCE Engine Block..???
    Is this the Block you are working on??
    Aluminum Olds Racing Block??
    http://www.gmpartsdirect.com/perform...ATID=1323.html
    My Blue Stuff:
    Nov 2013
    7
    Yes, it is a KB Olds block
    Nov 2003
    3,846
    Smile
    Had a feeling that might have been the one...
    My Blue Stuff:
    Nov 2003
    3,846
    Question
    Only 87 miles from Sarnia to Chris Razor's shop in Plymouth, MI...
    you might consider having him do the welding for you..
    it is a pretty expensive block.. and you may not want to practice on it..
    just a thought..
    My Blue Stuff:
    Nov 2013
    7
    just a thought..
    I kinda wanted to give it a whirl myself..........you don't learn if you don't try mentality
    But your probably right,.... Man, after watching those YouTube clips, those inverter Dynasty machines are incredible (able to weld thick sections, to thin, without preheat to the heavy area)
    And yes, Chris Razor OBVIOUSLY has the skills to do the job correctly!
    Well, I also have a set of Magnesium valve covers that need some corners added to them..........I definitely wouldn't attempt that job myself, so maybe I'll kill two birds with one stone and take them down with the block.
    Thanks, Dave
    Nov 2003
    3,846
    Smile
    TIG welding with a Dynasty is a whole new world..
    They're not your Daddy's Syncrowave..
    If you would like to see some real magic... take a look at John Marcella's work..
    this is from another old thread
    There are some guys that have brought sheet metal manifolds to an artform..
    John Marcella is one of them... his work is just beautiful..
    Here are some videos...
    http://www.youtube.com/watch?v=RGPgsXwgQkQ
    http://www.youtube.com/watch?v=Db6BVMANvW0
    Here is the link to his website... lots of pics
    http://marcellamanifolds.net/images/Images.html
    (And yes I realize it is an old thread..and that some have seen this work.. but it is so nice... it may serve as an example of the art...)
    My Blue Stuff:
    Nov 2013
    7
    Yes, I've seen his work..........he has some SERIOUS Tig welding skills!
    His stuff is total perfection! Pieces of art...... under the hoods of race cars
    Nov 2013
    7
    H80N,
    Sent you a PM
