Results 1 to 8 of 8
    PA
    363
    Default Goofy projects using the same item.
    Got a bunch of these stainless steel wire racks a while ago and stashed them as I couldn't figure out a use for them. They are 10 1/4" x 10 1/4" and have feet and a handle.
    After a while, I found a use for them.
    1 - Rack to smoke baby back ribs. Cut off the feet and handle and welded 1/4" ss tubing to the edges. The racks slide into another one which has ss rods to hold them vertically.
    2 - Turkey fryer basket. Tacked 4 of them together and rolled them into a cylinder.
    Used another for the bottom with corners trimmed to fit my 5 gallon ss fryer pot.
    3 - Another basket (used 2 racks for cylinder and one for bottom) to fry other stuff in a smaller pot so I don't need to use 5 gallons of oil each time.
    4 - Crab trap - won't rust although it is a bit small.
    Would love some other ideas for uses as there are just so many friends I can give cake cooling racks to as gifts.
    More photos to come
    PA
    363
    Default Goofy projects using the same item. - Part 2
    More photos
    Have used the fryer basket several times for deep frying turkeys and it works well.
    Burner is from a roofing torch as I found the regular turkey fryer burner was not providing enough heat to do the job.
    May 2011
    Bossier Parish La.
    550
    I need a basket for my turkey frying pot so I can use it to boil Crawdads this spring. How did you luck out and score these racks? Looks like you are finding a good use for them.
    PA
    363
    Bistineau,
    These racks came in a pile of stuff I got from a pet food store which was moving to a new location and selling stuff cheap.
    Also got a bunch of these stainless steel lids.
    3 1/2" OD with a 2" hole.
    So far I haven't come up with a use for them.
    Sure could use some ideas.
    Nov 2013
    Toronto
    46
    Great imagination.....why am I hungry?
    May 2011
    Bossier Parish La.
    550
    Quote Originally Posted by @cvmechanical View Post
    Probably because he mentioned he got them from a pet food store.
    Sep 2009
    South Carolina
    571
    Quote Originally Posted by bistineau View Post
    probably because he mentioned he got them from a pet food store.
    lol
    Nov 2013
    Toronto
    46
    Lol.....no!
