Results 1 to 2 of 2
    Nov 2013
    Default Miller Starfire windings
    I have a Miller Starfire 2E found bolt in stator windings, and it shorted out and
    burnt the windings. Live in Texas and cant find anyone ton rewind it. If anyone
    knows someone would thank you a lot. Even a used stator. would me good.
    8,182
    Keep looking on ebay, probably likely that you'll find one. As for winding, you'll need a shop that does micro windings, and they will need a spec on the stator, Good luck with that as it'll cost you MORE than the machine cost new!
