Results 1 to 3 of 3
    Sep 2012
    26
    Default millermatic 252 RUN function??? what is it good for?
    normally 20volts works good with 1/4 " carbon but change the RUN setting and it can run too hot or too cold. ( hold trigger when turning on this machine,then let go. you will see what i mean!) Functions might be there to help but every time there is a new function i come acrossed i am confussed. mig machines without this can run a open root with 18 volts downhill!
    3,945
    My MM252 at work changes V and wire speeds on its own. Can run all day then something doesn't seem right and then yup it changed. Somedays its real hot and other days its cold...Bob
    Nov 2012
    Northern Arizona
    540
    Are you talking about run in speed? My 251 has that. It adjust how long after you pull the trigger that the wire starts feeding. I think I have mine set around 80% if I remember right. PO had it are around 60% just personal preference.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
