    Nov 2013
    Washington DC area
    6
    Default Syncrowave SD 180 no high frequency
    Folks -
    Trying to troubleshoot my old (LA 081331) SD 180. I get no HF just a little (1/8 in spark) and thats it at the torch. When I checked the spark gaps, one of them was shorted - Probably had some grit blown into it. Readjusted the gap and now nothing at the Spark Gaps of 0.012. I checked T3 without power and get continuity at the primary side and 6K ohm on the secondary (That seems a bit high to me). The cap shows open but I can't check to see if its working. Continuity on T4 windings seems good. The foot switch (switch and 1K pot) is working as well. I can hear gas come on when i hit the foot switch and there is current at the torch (spark when i hit the electrode to the work material)
    Anyone have any ideas?
    cheers,
    -jim
    Nov 2003
    3,344
    Question
    Quote Originally Posted by jim.2435074 View Post
    Folks -
    cheers,
    -jim
    I would pull the covers and blow it out with compressed air...
    you likely have HV leakage from dust accumulation/carbon tracking..
    Have you had the HF set to continuios with the covers off in a dark room??..
    you might be able to see the blue corona of the HV leakage paths...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Nov 2013
    Washington DC area
    6
    Yeah I did blow the machine out, and did a quick look for a high voltage spark leak in a near-dark garage ... did not see or hear anything ... Will do it again and pay more attention this time.
    Does 6K ohm seem right for T3 secondary? that seems a bit high for a coil winding to me.
    cheers,
    -jim
    Nov 2013
    Washington DC area
    6
    cheers,
    -jim
    Thanks to the friendly folks at BR Welding Supplies White Plains MD, I was able to get some data on the SD180.
    1. The 6K ohm on T3 secondary was correct.
    2. looked for an HV leak and didn't find it - But did not expect to cause
    3. No 120V on T3 primary when I hit the remote pedal (reads 0V AC) - which is kinda weird cause I can sometimes get a small spark on the spark gaps / torch
    Gonna start working my way up to the main board and look for 120V ... Anyone have any ideas?
    cheers,
    -jim
    Oklahoma
    714
    cheers,
    -jim
    I believe many Miller technicians have recommended HF points gap be at .008"
    instead of the manual spec of .012".
    Probably can find this recommendation with a search on this forum.
    Griff
    Nov 2013
    Washington DC area
    6
    OK, This is the excuse I was looking for.
    No 120V power to T3 from the main board. A replacement board is almost as much as the resale value of the machine. Will take my time / chances and look at the main board, but in the mean time ...
    I have ordered a Dynasty 280DX from Oxygen Supply Company (aka BR welding) in White Plains, MD. More Welding Power, less current draw, light weight and lots of bells and whistles!
    cheers,
    -jim
Tags for this Thread
