Results 1 to 10 of 11
    Feb 2014
    2
    Default Welding Table Height (What do you consider the best Height)
    I just found a piece of 77x42 1/2X3/4 plate at our local salvage yard. I plan to make a new welding table out of it (if I ever get that chunk of Iron out of my truck).
    My question What is the best finished height for one?
    Salem ,Ohio
    3,861
    Cool
    Depends how tall you are...Bob
    northern NJ
    1,794
    It also depends on the type of work you will be doing. Mine is about 30" high, about desk height. I like it because it's easy to climb up on when building stuff & also if you have a large object it is easier to weld on the top. I use an office chair for tig work. I can always block up items on the table or block up the table itself if needed. If it's to high to start then you can't make it lower.
    MM250
    RCCS-14
    Sep 2007
    Medford MA
    535
    Woodworkers spend a lot of time discussing this.
    There are several books on building woodworking cabinets, benches, etc.
    They have some reasonable guides and rules of thumb for this
    Frank
    Oct 2007
    Cave Creek Az
    929
    37" is the absolute perfect height..... For me.
    Feb 2012
    NY
    93
    27 inches for me. Low enough to sit down and tig, still use a positioner without being to high and if I have to bend to work on something once in a while then so be it. Im only 5'6" tho, so thats my preferance.
    Oct 2006
    Illinois
    587
    I like a taller table, 36'' to 38 ''. Sitting on a stool is just right plus the additional height helps bring the work closer to my eyes; eyes ain't what they used to be. Plus when standing it's easier on your back.
    See what height feels good to you. There is no real right or wrong height. Being comfortable is the key. Sitting down resting arm on the table is nice unless the table is low they your back starts to bother you.
    If it's too tall you could weld in high heels .
    Make it the same height as other work surfaces u have then if u are working with 20 foot lengths and such u can easily support them for chops swing etc
    4,363
    That is a nice size, plenty long.
    May 2011
    Bossier Parish La.
    502
    Quote Originally Posted by yogi93555 View Post
    For a table you intend to stand at to do most of your work, about waist high, belt level, whatever that happens to be in your case. If you intend to sit at times to work at the table, just build your own custom height stool, or make it adjustable in height .
