Results 1 to 10 of 10
    Jan 2013
    Ohio
    57
    Default welding rot iron
    Excuse my spelling...have a job coming up on some decorative rot iron landscape fencing....was wondering what would be the best process to use...mostly re-tacking the tacks broken....thanks in advance
    2,914
    How decorative?
    Scrolls Pickets and such can be plain old mild steel.
    Some of the more ornate stuff is cast iron.
    2,914
    Jan 2013
    Ohio
    57
    I haven't seen it yet so don't know how decorative....was just told about it
    Oct 2009
    New Mexico
    43
    If it regular steel just tack again with stick. Pull up, tack, tack, tack, roll up and roll out...
    Nov 2009
    western mass
    208
    unless its about 150 years old its most likely not wrought iron. most likely mild steel. newer stuff has those Chinese cast iron points on them.
    Wa
    624
    All deco steel I use is mild, except for the stuff that is obviously cast, such as post caps, baluster shoes, some fence toppers, etc. you should be able to see an obvious difference between the cast and mild steel parts. Everything decorative steel I mig. In fact I was just working on a handrail and baluster system with mild steel hammered edge tube. Migging it all day. When I have to set cast post caps or similar I just epoxy them.
    Jan 2013
    Ohio
    57
    Here are some photos I took haven't gotten a chance to see what type of metal it is
    Dec 2011
    418
    Looks like cast iron panels in a mild steel railing. Are you going to sandblast and repaint it?---Meltedmetal
    Jan 2013
    Ohio
    57
    Metalmaster....I don't have a sandblaster
