Results 1 to 2 of 2
Thread: shopmaster 300
    Mar 2012
    Southwestern Ontario
    44
    Default shopmaster 300
    I have a shopmaster 300,curious if the fan is suppose to run all the time the unit is running? Also wondering if it's suppose to is there a way I could put a thermostat on the fan so it only runs when it needs to?
    8,325
    Quote Originally Posted by rustymfg@hotmail.com View Post
    Depending on the serial# yes, Putting a thermostat (actually 2 or 3) in there may be a problem with heating parts that you don't want to get heated. You can put a switch in to turn off the fan
