Results 1 to 10 of 17
    Nov 2011
    159
    Default millermatic 252 settings cards
    To the 252 owners;
    Do you find the settings charts on the front of the machine to be generally on the cold side?
    Running
    ER70S-6 wire 0.035
    CO2
    1/2 second pre-flow
    2 second post flow
    Should I be using the thickness gauge tool instead?
    2,942
    The charts are just suggested starting points- adjust as needed.
    Apr 2012
    Ohio
    39
    Straight CO2 will have different settings than 75/25
    Northern California
    214
    Yes, straight C02 runs hotter than the settings shown on the cards. I welded some 1/2" 1018 plates on a bevel joint recently. The settings were shown as 29.5 V (basically wide open) and 5i5 IPM on wire speed. I tried that and had to back down to 26 volts add 450 IPM and that was fine with .035 wire.
    I think the settings would be very close with 75/25 gas.
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
    Nov 2011
    159
    Yup I did use the recommended settings for CO2 and noticed I needed to up the voltage.
    Thanks for the feedback
    Northern California
    214
    Quote Originally Posted by ericher69 View Post
    Sorry, you misunderstood. CO2 runs hotter. Therefore it was necessary to lower the voltage.
    Milermatic 252
    To the 252 owners;
    Running
    ER70S-6 wire 0.035
    CO2
    1/2 second pre-flow
    2 second post flow
    The charts are way off
    Miller Dynasty 700
    Miller Dynasty 200
    Miller 350p
    Miler 252
    Hypertherm 1250
    Hobart Handler 187
    Lincoln 210
    Practical cnc
    Nov 2011
    159
    Quote Originally Posted by Synchroman View Post
    It may be the case for you but I've found so far the chart is cold even with CO2 therefore I've had to raise voltage
    Wa
    643
    What length stick out are you running?
    Nov 2013
    Toronto
    46
    I always go up in settings by a gauge if welding 1/4" I use settings for 3/8" and so on running .035 with 75/25
