Results 1 to 8 of 8
Thread: Xmt 350
    Corunna Ont, Canada
    455
    Default Xmt 350
    Hey Jeff, I got a XMT350 that I am working, I replaced the power connect board, caps.
    So I changed those parts turned the machine on (wired 240 single phase) got nut'n but CR1 just keeps clicking on and off.........
    green LED on top board on and blinks once every 2 sec or so
    no voltage at caps.
    Any idea??
    Thx Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    8,281
    Shoot me your email address and I'll shoot you the tech manual. You'll need a good meter then follow the prepower check list
    Corunna Ont, Canada
    455
    Thx Jeff
    tynemoore@yahoo.ca
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Corunna Ont, Canada
    455
    Ok checked out the pre-power checks
    Failed on MOD2
    Boost Snubber Diode L2 to TP4
    Main Boost Diode TP4 to +BUS
    Any ideas? Failed MOD2?
    Thx Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    8,281
    Mods 1 & 2 must be replaced together, and the interconnect board is also toast
    Corunna Ont, Canada
    455
    The interconnect board is brand new,
    You got and mods for sale?
    Thx Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    8,281
    Nope as mod1/2 and the interconect board are all replaced at the same time. If you replace just the interconnect board, and run it with a failed mod, 99% of the time you've just taken out the interconnect board again. now since mod 2 is shot, what is the condition of pc1
    Corunna Ont, Canada
    455
    PC1 seems to check out all fine as per the rest of the per-power checks
    Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
