Results 1 to 3 of 3
    Sep 2013
    16
    Default direct fit tig torch hose
    Im looking for a super flex red hose for my Diversion 180. If there is one out their, will i be able to hook it up to my welder without voiding the warranty?
    Nov 2003
    3,690
    Quote Originally Posted by brettbuck View Post
    The Diversion series uses a Weldcraft 12.5 ft 17LS torch... The original part was a 57Y01RLGC
    here is the parts sheet..
    http://www.weldcraft.com/pdfs/WP17ENG.pdf
    the right part number MIGHT be
    57Y01SFB . . . . . . . Cable, Power 12.5’ (3.8m), Braided, Black
    But I would confirm that first... (it may need an adaptor and might not be as flexable as you seek) )
    http://www.weldcraft.com/pdfs/o225427d_multi.pdf
    Here is a video on torch head replacement that will give you a better idea as to how it goes together
    http://www.youtube.com/watch?v=De7xfyhf1Ak
    HTP does make an adaptor fitting to connect aftermarket torches to the Diversion..
    http://www.usaweld.com/Miller-Divers...p/mildivck.htm
    that might be a simpler answer all the way around
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Aug 2009
    142
    Just another idea - which I used with my Diversion 165...
    If you get an AW-430A coupler you can attach most any standard super flex cable onto the end of the hard wired Diversion cable. The Diversion cable can be left coiled up at the machine or used for extended reach. Just make sure you insulate the connection. I used a piece of heater hose over the splice and it worked fine.
    Ken
    p.s. Of course after a few weeks I disconnected the super flex hose and connected it to my new Dynasty 200DX
