    Default Do You Stick w/ Your Dynasty 200 DX?
    I've only used my Dynasty 200 DX to stick weld a couple of times (6010/7018). Doing so introduced me to what welders meant when they said sometimes they found stick welding to be like spreading butter. A whole other world from any other machine I've used.
    But my question is would you or do you use the machine a lot for stick welding or solely for Tig? "A lot" is pretty subjective so lets say it means one of two things:
    - Use it for everyday production work.
    - A newbie uses it to run bead after bead after bead for practice (yes, observing duty cycle limits).
    Sep 2009
    South Carolina
    571
    I use mine for Tig, I have stick welded with it but most on my stick welding is mobile now with an engine drive so I leave the Dynasty set up for Tig.
    Using it everyday for stick would bother me a little because like you I don't know the ends and out of inverters with sticking rods etc but I wouldn't think it should hurt it. If I needed to stick weld with it I would,,, if there is access to a stick machine, then I would use it instead.
    Nov 2003
    3,520
    Smile
    I do mostly TIG these days....
    Both my Dynasties 200DX & 350 Tigrunner have have been used strictly for TIG and never burnt a stick..
    not that they couldn't... but I just don't do any stick welding these days..
    Anything that might have seen stick in the past now gets MIG'd with either the MM350P or MM200...
    just my personal preference... no reflection on the Dynasty's ability to run stick...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Nov 2013
    Toronto
    46
    "not that they couldn't... but I just don't do any stick welding these days..
    just my personal preference... no reflection on the Dynasty's ability to run stick."
    Exactly what I was gonna say
    Quote Originally Posted by stickermigtigger View Post
    ABSOLUTELY NOT!!! I love my Dynasty!!! I bought it for the advance features of tig! I can buy a cheap machine to stick. You don't need to fine tune a stick machine. Just adjust your amps. I am not getting nasty-but a Dynasty is a waste as a daily stick machine! Sorry! My opinion!
