Results 1 to 10 of 10
    Mar 2007
    Mobile,Al
    108
    Default Miller Dynasty Dx 200 Tig Runner Package ?
    I just purchased the Dynasty Dx 200 , I wired it up to run 460 volts , my first time hearing this machine run , I think there is an electrical issue internal in this machine .it welds fine but, I hear an electrical arc not a fan but something of that nature when the machine is in Idle . Is this common....
    I would expect to hear a fan , it just raises my concern there is something going on inside that is not right.
    Any help would be appreciated
    Ps : I don't feel the fan running
    Nov 2003
    3,520
    Smile
    That machine has "Fan on Demand".... so it does not run all the time... just when hot... which is not very often...
    on the arcing sound... ... inverters make a different sound than transformer machines... probably normal...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Nov 2013
    Toronto
    46
    Kind of an electronic whining sound? That's the noise mine makes on 220 volt
    Nov 2003
    3,520
    And the Tigrunner version has the Coolmate cooler... the pump on that is pretty noisy as well...
    My Blue Stuff:
    Millermatic 200
    Mar 2007
    Mobile,Al
    108
    Thanks , I was just unsure of that sound .
    Wanted to make sure .
    I have only stick welded with it thus far . Can't wait to get finished with this pipe job I am on so I can get home and play with it on the high frequency side , and aluminum capabilities .
    Thanks for quick response!
    Feb 2012
    Wa
    629
    You may want to take it to your lws and have them have a listen since they have surely been around properly running dynasties.
    Mar 2007
    Mobile,Al
    108
    Quote Originally Posted by @cvmechanical View Post
    Yes!!!!
    I'm hoping that's usual with this machine...
    Nov 2013
    Toronto
    46
    I believe from videos on you tube and from what I've heard that's the norm.
    Aug 2006
    Melbourne, Australia
    107
    The electrical "noise" is the Autoline voltage sensing system and is common through the Dynasty range.
    Both mine and my mates Dynasty 350's make the same noise.
    Regards Andrew from Oz.
    We are tig welders, gravity doesn't worry us.
    Miller Dynasty 350 Tig.
    OTC AVP300 AC/DC 300 amp hybrid wave Tig. (now retired)
    Kemppi MLS 2300 230amp AC/DC Tig for home with all the bells and whistles.
    Mar 2007
    Mobile,Al
    108
    Quote Originally Posted by awill4x4 View Post
    Thank you!
    I just did not expect to hear any noise coming from it .....
