    May 2008
    Troy, MI
    354
    Default Slide Hammer Dowel Puller
    At work we needed to pull out a blind press fit dowel.
    I drilled and tapped a block of steel to match the M16 x 1.5 thread that came on the puller and welded it to a Vise-Grip pliers.
    It worked great.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    354
    Here is a link to a video describing the construction and use.
    http://www.weldingtipsandtricks.com/slide-hammer.html
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Dec 2012
    Front Royal, Va
    64
    Looks really nice. Glad it worked and good info to know.
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
    Upstate SC
    143
    Default An alternative way:
    Nice work.
    But for a one-time job, I made a vise grip slide hammer puller without welding.
    I just made a hook attachment to the slide hammer to grab the inside of the vg jaws.
    Used it to pull a deep bearing shaft out of my Norton gearbox.
    cg
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
    1,897
    Gotta love Vise-Grips. One of the best tolls invented. (only the good ones, not cheap junky ones)
    The slide hammer I have came with an adapter that has the same external thread and spherical end as the adjustment bolt in a vise-grip pliers on one end and an internal thread that the hammer bar threads into on the other. I didn't know what the darn thing was for at first but since I figured in out I have put it to good use.
