Results 1 to 3 of 3
    Sep 2009
    South Carolina
    571
    Default New Job Old Memories
    Got a small job today at my old elementary school, hadn't been it since I was 12yrs old, fitty now.
    Its been kept up but not a school anymore. I was floored. No words for the feeling as I walked into the place and down the main hall. It was like I was watching some kind of movie or had died and came back. Kind of seeing me from 6 to 12 in the place. Yea weird I know, but that was a first for me ever, being confronted with so many memories at once.
    Oh yea, welding. Clips on the bottom of seats where they have plays now. Probably spring steel. 16 gage, Have to make some replacements. Guess I'll use mild steel. They only have to install once. Just holds the seat bottom as it spring folds up when someone gets up.
    Weld the found clips on with tiny tacks all around and hope for the best. Have to move back the fabric and foam and I ain't no seat fixer but I couldn't leave them without trying to help.
    Any suggestions for 16 gage spring steel source? 1" wide, 2 1/2" long have to bend like a Z sort of.
    Oct 2009
    306
    Your local steel supplier should be able to order it for you. If not check out McMaster Carr
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2008
    west edge of the RRV
    69
    Know anybody that uses larger band saw blades? Grind the teeth off a piece of scrap blade. I've used a bunch from a portable sawmill to make things.
