Results 1 to 7 of 7
    Default sub arc seam welder
    What are the best settings for a root pass new machune in shop tryna fugure it out
    8,104
    You have ALOT of variables here, ie, wire size, type of wire, subarc flux used, type and thickness of welded material, WAYYYYYY to many variables actually.
    5/32 wire about a 1inch to 1 1/2
    Lincoln flux
    Regular carbon steel pipe long seam
    8,104
    Your going to have to contact your tech rep, as you haven't told me which lincoln flux your using. Nor the powersource, nor the feeder.
    Oct 2009
    306
    5 or 6 more posts and we might have all the info to help. Let's cross our fingers.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
