    Nov 2013
    7
    Default Should preheating be required to fillet weld half inch thick aluminum?
    Hey there guys. I got a question i want to throw out your way. So i need to fillet weld a 4"x.5" aluminum flat bar to another 4"X.5" flat bar. The alloy is 6061t and my filler is 1/16th 5356. Ill be using a miller aluma pro with a miller deltaweld. Now the question...should i preheat this or can i just weld. The peices are about 19 feet in length. So there you go..if you need more information about this project let me know.
    Aug 2012
    Hermiston Oregon
    278
    Bevel both sides
    tack ends
    Clampon a flat surface
    preheat 200-300f
    Weld.
    Flip clamp.
    weld .
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    1,895
    I would pre-heat the beginning so you don't get a cold start. Once you are burning wire you should be fine.
    Aug 2004
    Milan Michigan
    1,806
    Eecervantes 83 is probably given a better pre heat temp since its only 1/2" thick, I was preheating to 400 degrees because my blocks of aliminum that I was welding were 7" thick x 2' wide x 5' long and would pull the heat away from my weld zone extremely fast.
