Results 1 to 7 of 7
Thread: 'Baking' Rods
    Oct 2013
    Default 'Baking' Rods
    I have about 20# of 6011 and 6013 1/4" rods that seem to be damp. They were just not stored properly but are not wet.
    Can I 'bake' them in a oven to make sure they are dry and then store properly??
    Thanks guys
    4,435
    Don't bake, just dry them out in the house.
    Jun 2013
    20
    If you do. They will stink the house up and if 6010 6011 I don't know how they will react. I dried out a box of 7024 and had trouble with cracked flux.
    May 2008
    Belle Plaine Iowa
    270
    "dry them in the house" meaning in a slightly warm oven or just in front of a furnace vent or simply dehumidify?
    Miller AC/DC Thunderbolt 225
    Miller 180 w/Autoset
    Old cutting torch on LPG
    Jul 2008
    Flin Flon & Creighton area
    233
    Default You can "gently " bake them if they got wet
    I supposed the question is how damp exactly did the rods get , If they got so wet that the flux is gooey mud , than you should probably pitch them. If you can still pull individual rods out without the flux coming off or sticking to the other rods, bake them. 6011 is a great deep penetration rod, the coating actually functions with a small percentage moisture content. if memory serves me correctly i read between 4 - 7 %. If they are too dry they dont burn as well and, you may notice they are not as quite as penetrating as the metal transfers across the arc. At trade school we were often advised to open a new box of rods and then leave them in the cabinet and in the presence of regular air , so that they would absorb some of the moisture. This makes a marked difference in how aggressively the rod digs as you weld. I also know that you can use this rod and 6010 as well soaking wet with high amperage as a cutting rod. Works great for demolition work. The 6013 should be stored in similiar conditions. I would bake them in the rod oven, or spread them out on a cookie sheet in your household oven and bake at at least 220 degrees for a couple hours , them package them again. Too much humidity in any rods is not good, Check for funky discoloration/mold and any obvious things that dont look right.
    I have a welding addiction
    Dec 2011
    416
    Recommendations courtesy of Lincoln:Redrying Conditions - Non-Low Hydrogen Stick Electrodes
    Stick Electrode
    Electrode Group
    Final Redrying Temperature
    Time
    E6010: Fleetweld 5P, 5P+
    E6011: Fleetweld 35, 35LS, 180
    E7010-A1: SA-85(1)
    E7010-G: SA-HYP+(1)
    E8010-G: SA-70+(1), SA-80(1)
    E9010-G: SA-90(1)
    Fast Freeze - excessive moisture is indicated by a noisy arc and high spatter, rusty core wire at the holder end or objectionable coating blisters while welding.
    Re-baking of this group of stick electrodes is not recommended.
    Not Recommended
    N/A
    E7024: Jetweld 1, 3
    E6027: Jetweld 2
    Fast Fill - excessive moisture is indicated by a noisy or "digging" arc, high spatter, tight slag, or undercut. Pre-dry unusually damp electrodes for 30 - 45 minutes at 200F to 230F (90 - 110C) before final drying to minimize cracking of the coating.
    400 to 500F (200to 260C)
    30 - 45 minutes
    E6012: Fleetweld 7
    E6013: Fleetweld 37
    E7014: Fleetweld 47
    E6022: Fleetweld 22
    Fill Freeze - Excessive moisture is indicated by a noisy or "digging" arc, high spatter, tight slag or undercut. Pre-dry unusually damp electrodes for 30 - 45 minutes at 200 - 230F (90 - 110C) before final drying to minimize cracking of the coating
    300 to 350F (150 to 180C)
    20 - 30 minutes
    (1) Pre-dry for 1 to 2 hours. This will minimize the tendency for coating cracks or oxidation of the alloys in the coating.
    As you can see 6011 re-bake is not recommended 6013 can be done. Again depends on what your welding if its not critical and the rods are not rusty/flaking I'd dry them(6011) in a dry ( low humidity) area in the house and see how they perform.---Meltedmetal
    May 2008
    Belle Plaine Iowa
    270
    In my case some dummy (me) left the rods sitting in the cardboard box on top of the welder in the unheated garage for a couple years. Now if you can actually strike an arc you cant really weld with it. I bought a new box and they work great. I was concerned something was wrong with the welder but now I know it's the rods. Id like to salvage them if I can.
