Results 1 to 1 of 1
    May 2012
    4
    Default rmd root pass on sch 40
    new to the rmd process and not sure where i should be setting the wire speed? using .035" wire on sch 40 carbon pipe. also what gas mix other then c25?
Tags for this Thread
