Results 21 to 30 of 31
  1. #21
    8,231
    Now the HF only starts the arc, doesn't matter if its AL or steel. The inverter monitors the arc after starting, so thats all your after. But you realize this right.
  2. #22
    8,231
    maybe get me the correct serial# too
  3. #23
    Feb 2013
    27
    The correct SN is - LH500798L. I do understand that HF is not continuous 100%, but with my torch isolated from the workpiece and pedal depressed or A-B jumpered the HF spark gap should be continuious until a weld arc is sensed by the machine.
    The outlet I plug my welder into is a NEMA6-50 wired into a subpanel for the garage. The garage subpanel has a good ground rod driven into the ground about 4 feet from the panel. The welder outlet wiring runs straight into the subpanel and is tied into the ground bus. There are no other active circuits in that panel while I'm welding.
  4. #24
    8,231
    Did you use the Black and the white wires for the welder, or did you use the red.
    Don't really care much where the panel is, The ground rod is kinda pointless unless you know exactly what the soil conditions are
  5. #25
    Feb 2013
    27
    The two hot wires from the breaker (Black and white) are hooked to the two top lugs of the switch in the welder. I am running it single phase. Measured between them is a perfect 239VAC. Measured between either one and the ground is 120VAC.
  6. #26
    8,231
    We never measure to frame ground from the hots, mostly because it means NOTHING. Anyway, just reopened the online manual, and that is correct.
    So have a looksee at the other stuff I mentioned. I'm leaving for the day and don't answer posts at home.
  7. #27
    Feb 2013
    27
    The only two items you mentioned that I couldn't check are:
    Torch - I don't have a second one to test
    Relays - I don't see anything externally burnt, but I don't know which I need to check. I finished most of the Troubleshooting section last night:
    Pg 82 Schematic Test Values
    R1,R2 =.3Ohm
    R3,R4 = 198 and 200 ohm
    R5 = I couldn't find where to check
    R6 = I couldn't find where to check
    R7 = One of the contacts here is labeled HF-XFMR (High Frequency Transformer?) I don't know how to test R7 because of the C3 capacitor in series with BUS-CTR. It appears this is a winding on T1. T1 pins are unlabeled on the PC3 board. Do you know how the pins are assigned?
    R8 = .2Ohm
    R9 = .3Ohm
    R10 = .5Ohm
    V1 = 16.1
    V2 = I don't know where to check. I don't see violet wires as labeled. This appears to be on T2, the main torriod transformer. I don't see any violet wires leaving it.
    V3 = 234
    V4 = 116.6
    V5 = 18.9
    V6 = 18.9
    V7 = 676
    V8 = 25V? Why is this low?
    V9 = 468
    V10 = 468
    V11 = Not checked
    V12 = -15
    V13 = +15
    V15 = No Voltage This should read +24, right?
    V16 = No Voltage This should read +24, right?
    V17 = +15
    V18 = +10
    V19 = +12 and waveform is good.
    PC1 Test Point Values
    RC1-1 to RC1-2 = 3.7
    RC2-1 to RC2-4 = 934
    RC6-3 to RC6-7 = 3.7
    RC6-5 = 14.7
    RC6-9 = 5
    RC6-11 = 5
    RC6-12 = 5 - The description says this means I have a Primary error? No help codes are displayed, do you agree this should read 0? If so what should I check?
    RC6-13 = 18.8
    RC7-1 = 15
    RC7-2 = 15
    RC8-1 to RC8-2 = 15
    RC8-3 to RC8-2 = 4.8
    LEDS ALL OFF
    PC3 Test Point Values
    RC20 to RC21 = .6? This voltage is out of limits
    RC25-1 to RC25-3 = .4 Is this OK?
    RC26-1 to RC26-2 = 16
    RC26-4 to RC26-5 = 16
    PC5 Test Point Values
    RC1 Checks = Tested as per PG 86
    RC2 Checks = Tested as per PG 86
    RC5 Checks = Tested as per PG 86
    RC7-1 to RC7-2 = 15
    RC7-9 to RC7-2 = No Wire, No volts noted - This isn't correct is it?
    RC7-16 to RC7-10 = 935
    RC8-1 to RC8-3 = 321.6
    RC9-1 to RC9-6 = 16
    RC9-3 to RC9-10 = No Wire Present (Do I need a probe that will fit deeply into the socket?)
    RC9-4 to RC9-5 = No Wire Present
    RC9-8 to RC9-10 = 18.8
    RC9-9 to RC9-5 = Not Checked
    RC10-1 = Not Checked
    RC10-2 = Not Checked
    RC11-1 = Not Checked
    RC11-2 = Not Checked
    RC11-4 = Not Checked
    RC11-5 = Not Checked
    RC11-6 = 25 Is this OK?
    LED1 = OFF
    PC6 Test Point Values
    RC1-1 = 0
    RC1-2 = 0
    RC1-3 = 0
    RC11-1 = 3.6
    RC11-2 = 3.7
    RC11-3 = No Wire
    RC11-7=4.9
    RC11-14 = 5
    RC11-15 = 5
    RC11-16 = 14.7
    RC13-22 = 15
    RC14-1 to RC-14-8 = Erratic with Amphenol A-B jumpered or not.
    RC14-3 = 25
    RC15-2 = 14.6
    RC15-3 = 4.9
    RC15-4 = 4.9
    RC15-6 = 4.2
    RC15-12 = 4.9
    RC15-14 = 4.9
    RC15-17 = 4.9 Does this seem high?
    RC15-18 = 4.9 Does this seem high?
    RC16-1 = +15
    RC16-2 = -15
    RC16-3 = =25
    RC16-4 = -25
    RC17-2 = 4.9
    RC18-6 = 10
    RC18-8 = 15
    PC7 Test Point Values
    RC1-1 to RC1-3 = 321.6
    RC2-1 to RC2-2 = Erratic. No appreciable voltage, no steady ~700hz.
    PC8 Test Point Values
    RC1-1 to RC1-2 = 16
    RC1-3 to RC1-6 = 4.9
    RC1-4 to RC1-5 = 16.1
    RC1-9 to RC1-8 = No Wire at RC1-8
    RC2-1 to RC2-4 = 935
    What do you think?
  8. #28
    8,231
    Pay the piper, and take the unit in to a CST Miller tech. If they have no CST guys, take it, or send it somewhere else.
  9. #29
    Feb 2013
    27
    Aww, this is just as I was beginning to have fun... I don't want to give up.
  10. #30
    Feb 2013
    27
    This info is for anyone who has a similar problem. My original idea regarding the source that drives the HF board was correct. PC6 SENDS the signal to the PC7 board that tells the PC7 board how fast and when to make HF. The 700Hz signal that we couldn't find was not coming out of the PC6.
    I replaced my PC6 board with a brand new PC6. Problem solved. The initial info from the troubleshooting/service manual was good.
    Thanks for your help over those weeks Cruizer.
    Case closed.
