Results 1 to 10 of 13
    Oct 2013
    27
    Default Tig welding cast iron?
    Hey guys I want to Tig weld some cast iron, but I don't know what kind of tungsten I need to use, And what filler I need?
    Apr 2013
    Southeast idaho
    30
    What are you welding? (Vise. Repairing a casting?)
    Oct 2013
    27
    Engine block
    Oct 2006
    Mpls, MN
    1,790
    You need high nickel rod or it'll crack as it cools.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Aug 2012
    Hermiston Oregon
    204
    Hey jim
    I stick weld cast with utp55 rodwhats that equal to in tig rod?
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Oct 2013
    27
    And if I was welding on a vise or old yard art I can use stainless. 308 filler?
    Oct 2006
    Mpls, MN
    1,790
    You can scrape the flux off your electrodes and use those for filler with TIG.
    I've had no luck with anything cast iron and 308/309. Doesn't matter if I preheat, acetone soak, sacrifice animals... always cracks on me right as I think it's going to hold. TING!
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Aug 2012
    Hermiston Oregon
    204
    Get you some fire bricks
    Build yourself 3 walls and a plate ontop to enclose the heat . Use a fiberglass blanket and wall insulation.
    Weld as u normally do . And right as your done shove it into the enclosure. Pack it with insulation and wait 24hours . Itll cool down really slow .its always worked for me .
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Oct 2013
    27
    Ok thanks
    Quote Originally Posted by DPSwelder View Post
    Ok thanks
    I have tigged with I think monel /nickel 60 rod or something with good results. Generally 60-60 nickel rods are good. I have also used stainless but despite being very strong it does not tolerate flex AT ALL....
