    Jul 2009
    22
    Question Miller Vintage Performance Drop Off
    Hey guys,
    I have a question. First understand what I do not know about welders and welding would fill volumes and volumes.
    I have a Miller VINTAGE welder running 220 from a house line. There is maybe a 50' extension cord from the meter to the machine.
    I start to weld and I can get some good bacon sounds going but maybe 3-5 minutes into welding it seems like the voltage drops or something goes awry. It just seems like it's strength drops off.
    Is there a name for this and is there a part inside I can change to try to fix it?
    TIA!
    Artisan
    Jul 2008
    Delhi, Ontario:
    1,972
    Quote Originally Posted by .Artisan. View Post
    Hey guys,
    TIA!
    Artisan
    What gauge is the extention cord ?
    ........Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    8,018
    100% likely its the gun, try replacing the liner first.
    Cave Creek Az
    1,037
    I recently had a loose screw on one of the terminals on one of my cords.
    Jul 2009
    22
    Quote Originally Posted by nfinch86 View Post
    ........Norm
    Norm it is a Yellow heavy x-tension cord. The OD of the cord is 9/16" .
    Jul 2009
    22
    The liner was replaced in recent past, what would you suggest 2nd?
    Midwest
    765
    Does the cord or plug get warm?
    Cave Creek Az
    1,037
    Liner can be ruined the day it is installed. Pull it and check it out.
    8,018
    Liner, tip, or plugged wire guide to the drive rolls, especially if you using a absolutely useless lubricated wire felt cleaner.
