Results 1 to 10 of 14
    Oct 2013
    3
    Default Running a 211 Millermatic off of a generator
    Hey guys, new to the forum and looking for some help. I purchased a 211 3 years ago and love the machine. I bought a new place and trying to do some light welding on a gate. No power at the gate location so I fired up a portable generator to power the 211. The welder runs but won't advance wire or arc. With house power welder works fine. Generator voltage comes in at 140v. Any ideas on what's going on? Just need to weld a couple of tabs on the gate posts before I have shoulder surgery. Thanks Larry
    Los Angeles
    2,862
    You didn't state what size generator
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Oct 2013
    3
    Sorry, it's a 3500 watt 120v. Larry
    Los Angeles
    2,862
    Check to make sure that the switch on the front is set for the regular mig gun and not the Spoolgun.
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
    Los Angeles
    2,862
    Quote Originally Posted by High2 View Post
    That should be enough power but your 140v at the receptacle is really high
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
    Oct 2006
    Illinois
    600
    From reading posts on using generators with welding machines it must be ran on high idle at all times .
    Looking in the manual you need at least a 20 amp circuit with 110 volt plug. Is yours a 20 amp ?
    Nov 2012
    Northern Arizona
    479
    110vac x 20amp = 2200 watts. Should be good to run on the 110vac side which would be fine for 1/8" steel no problem. Did you try again in the shop or idle the genny up to make sure it was ready to go? Also probe the generator output to verify voltage and ac frequency?
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
    Feb 2012
    226
    Voltage is to high at 140.
    Oct 2013
    3
    I've tried everything that I can think of. Like I said the welder runs but won't advance wire when the trigger is pulled. Unplug and connect to shore power, everything is fine. The 140v is too high, maybe a built in safety in the welders circuitry. Larry
    Los Angeles
    2,862
    Did you check the Gun selector switch ?
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
